fuel leak above starter
A_G
oklahoma
So I had the trans rebuilt, if ur wondering y I didn't just do it I've got a torn rotator cup, now its seems on top of the atf leak after 50 miles I have a huge fuel leak because my starter is soaked under dim light of my phone it seems that the back of the up is leaking but not near enough to soak the starter oil pan area.
Ideas?
I'm gonna do more investigating but I'm upon the hell part of my week 2 hrs off among 25 hrs so I won't get much tinkering time
A_G
oklahoma
Damn autocorrect, laptop quit so I'm down to the ol phone
Brianedwardss
Oregon City, OR
Check the fuel supply hose going to lift pump. Another place to check is the bottom of the IP, it may be leaking out the front weep hole area and running back through the valley pan. Also, the fuel return line goes over the top of the tranny, follow it up from the drivers side frame rail. Last time I had a fuel leak by the starter, my fuel filter had came a bit loose.
Good luck
gatorman21218
Ashland VA
Check the return lines on the injectors. it dont take much to bump one off and it really pours out the fuel. Ask me how I know.
Bo17
