Fuel Filter Wire
gabbyr100rs
Acworth, GA
Sometime between when my son took delivery of my truck, and when I got it back, the wire that connects to the bottom of the fuel filter bowl broke off.
The female connector to the bowl is there along with about 3" of wire. I have looked around the passenger side of the engine and cannot see a loose black wire anywhere.
I am assuming that the wire in question triggers the "water in the fuel" indicator, and I would like to find the other end. Do any of you know which loom I should look for and/or where it might be located? Some place under there is a broken-off 18-20 gauge black wire looking for its "other end". LOL
Thanks!
highest_vision
Reqistered User
Boone, North Carolina
I believe it will be in the glow plug harness, likely grouped close to the wires going to your filter heater and restriction. Work your way back from there.
Are you sure it was hooked up before ;) :D
James
bob123456789
