fuel filter head return line blocked off
yotekiller
Va.
got a question, got my return kit from Type4, well this truck the ever leaking return port on the filter head is blocked off with a npt plug.. my 89 has the metal return line on the drivers side which crosses over at the #8Cylinder.. i have line off the #1 inj. cap blocked with short hose and bolt and clamp, question is can i put a 90deg cap on #1cylinder and run it over to i believe that is #2cylinder with another 90deg cap, only issue is the only extra 90deg caps i have are the ones im taking off or is that a bad idea?
Good grief this should not be that hard to fix..
