pat_da_man
PatMan
Hi guys
New to this site
I am thinking about putting in a check valve just prior to my lift pump in my 92 7.3L f250. I'm wanting to do this because my fuel filter is draining, causing my truck to start and run for about 10-15 secs then stall and take about 30 secs of cranking to get it started again. After this it its good to go. If i fill my fuel filter with fuel it is good to go. It seems there is suction causing this, as if i unsrew the fuel filter and let it suck all it wants, then fill the filter with fuel it starts fine, even if it sits for a few days. Anyone see any problems with putting in a check valve or backflow preventer in? or anyone know any other solution?
Thanks
New to this site
Thanks
Lots of folks have struggled with air leaks, but throwing parts and money at it is not the best way. A few pieces of cheap clear vinyl tubing work wonders at locating the source. If you feel you must replace something, just scrap the mechanical lift pump and go electric. That has benefits all the way around.
so i cleaned it out and so far so good i guess its a good thing my truck has two fuel filters, but anywho now i am going to keep my eye out for a sweet deal on one of those fuel pumps while i try to fix the massive exhaust leak i found
