burner 350
after installing a 6.9 about 2 months ago trying to finish it now. built pressure up in my tank to get fuel in the lines got fuel to filter can not get any farther is their a trick to getting it past injector pump. thanks
What really needs to be done is crank the engine holding the throttle wide open so more fuel is pushed thru the lines. Stop cranking after around 15 to 20 seconds and crack open the lines at the injector nuts. Listen for the sound of escapping air under pressure. Look for fuel and bubbles. Then repeat this again. You will get all the air out and the engine will stumble to life. Some like to leave all the easy to reach injector line nuts loose and just crank till fuel squirts out. That works but its messy and you may get air pulled back in because the lines are loose. This is the two ways to purge the air from the injection lines....
