Front driveshaft yoke removal from '93 F350 T-case
PSDfreak
Diesel-a-holic
Newcastle & Chico, CA
First, I want to thank all of you for helping me with all of these little questions...you have all been very helpful!!!
Anyhow...I need to get the yoke for the front drive shaft off of the donor t-case (1993 F-350) to use for my T-case when I swap in the D60. It looks to be about a 32mm-34mm nut that is holding that thing onto the case, however, there is very little clearance to get an impact socket in there (walls of the socket are too thick). Anyone know exactly what size that is, and if so, what did you use to get that thing off???
Thanks,
Casey
I know that is an issue on the rear facing yoke also. You definitely need a thin wall socket.
hesutton
The Anti-Anderson
Bowling Green, KY
Those come off with a thin socket and an impact as Mel said. I can't imagine getting an impact socket in there.:D
Heath
Dsl_Dog_Treat
Decatur,MI
Heath
Get an el cheapo impact and hit the outside about 1/2" up with the bench grinder and you can get em off in no time.;Sweet
