mattinthebox
Ford cab swap Q…
I have a 1987 Ford F-350 built as a flatbed/rollback/wrecker.
The floor of my cab has suffered thru many years of salted winter roads here in Michigan.
The floor, rockers & cab corners are completely rotted thru.
I want to swap the complete cab from another truck but have questions regarding fitment differences between donor trucks.
I’m curious what year ford trucks I can choose from?
Also is there any major difference between F-150, F-250, F-350 cabs that would prevent a simple swap other than suspension?
My F-350 was originally equipped with a 6.9l but has been replaced with a reman 7.3l idi.
I only have a 4spd, not sure which but I believe it’s a Borg Warner T-19a(?), & would like to upgrade to a 5spd (or other suggestions for a wrecker) as well which is why it’s fairly important I find the right donor which could possibly supply everything I need.
So first off, can anyone tell me what year range will work with my application?
I have an older Chilton manual which covers ford trucks from 87-93, is 93 when ford made changes?
Please correct me if I am wrong but I was under the impression that I could use cabs as late as 97.
Other Q’s are whether or not these parts will work without modification:
- Brake/Clutch pedal
- Slave cylinder
- Master cylinder & rod
- Body & frame mounts
- Electronic controls/wiring
- Instrument cluster
- Radiator core support for humongous diesel radiator
A few other luxuries I’d like to have made available in the new truck cab would be power windows, power locks, etc…
Also, concerning transmissions, does the 5spd (zf5) have accommodation for a PTO? I have hydraulics to operate my bed & a trans that'll work with my PTO is a must.
I’m hoping it’s a pretty straight forward changeover but wanted to consult with the members here to help me avoid the pitfalls & gain any tips/tricks that’ll make it a smooth process.
Many thanks in advance to anyone that can help.
- Slave cylinder
