Double-S-Diesel
parts seller
Never fails,
just been doiun some minor stuff to the truck , like wheel cylinders, that was afiasco, for some reason they were special.
then had ebrake issues due to the sping on the equilizer being missing, fixed that, ebrake has never been better. 2 outer tie rods, alighnment, front brake hose, leaky pinion seal, oil change, finally put the ford bracket in for the dash rattle. fixed pass side doo handle, got wipers working corectly,
found ps leak.
and found the antifreeze smell,
DANG HEAD GASKET IS BAD.
must be payback for all the attention the PSD is supposed to be getting.
Last time I was paying more attention to a PSD the dang motor blew up.
O well off to tear it apart.
Got part apart, found out only to be a leaky hose at the t stat housing.
of course I found this after removing the front bumper, grille, etc, draining the antifreeze, and evacuating the ac.
some new hoses, new belts , and bac together it goes.
found ps leak.
