fire wall questions
goldsjos18
wisconsin
hey guys im in the middle of a 7.3 psd engine swap and i just want to know if a fire wall that is in a 1995 will fit into a 1984 i would like to take the entire fire wall if i could because i also plan on swapping in the dash if you guys have any information on this kind of swap i would much appreciate your expertise
goldsjos18
wisconsin
From when I pulled the radiator out of the 7.3 and the bull nose they were the same size
goldsjos18
wisconsin
Pictures of the radiators out of the 7.3 and the 84
thanks! one less thing to worry about.
I have plans of making a 4 dr bronco with a 96 CC
and a bull nose front end.
thought the radiator I pulled out was super small, but it looks like im retarded :D
but to answer your original question, you can cut out your firewall and install the OBS stuff like I did on the duallie I did a conversion on back in the day.
goldsjos18
wisconsin
Your bronco might have a smaller radiator because I believe Ford had 2 different core supports for diesels and gas trucks
yup, but the front end is off a 85 F250 IDI truck.
only the rear portion of the bronco body is being used.
goldsjos18
wisconsin
sounds like you should be good then i want to see this when your done building it
next month ill get the body together, I have some other projects on the list infront of it.
no mufflers
rhode island
one thing to note on the radiator, the early PSD like 94-95 have a cap on the tank like the IDI would. the latter date PSD like 96-97 and kind of 98 would have the Dgas bottle on the fender.
cant remember if you have 2 of the same cabs....
just dawned on me today...
SWAP CABS!
they are all the same......
would turn a 2 week adventure into a Saturday bbq.
goldsjos18
wisconsin
yeah i could put my hand through the rear cab corners on the 94 the salt they spray and throw on the roads is like cancer for cars
