I'm going to be in the market for a 5'er tailgate when pulling this thing. The 1st pull went OK.
I have had a vibration in the drivetrain intermittantly after I added the ZF5. It is an inch longer than the C6 it replaced. I think it is the rear drive shaft. I will likely shorten it one inch and will probally replace the carrier bearing while it's out.
The US Gear underdrive makes getting up to speed much easier and with less EGT's. I love having that thing on the truck.
I'm pretty sure I need a set of injectors. I have a miss at times and I'm sure I have a bad one or two.
I need longer mirrors or at least mirror extentions. I can't see jack beside the trailer.
Overall, it's not too bad. Will be pulling it to the campground after work. I'll likely take an hour to back in the site.
But, once I get it back home, I'll need to address the vibration and the injectors.
Heath
