lakesurfer
I purchased the Ferret 765-01 Diesel Timing Adapter, and an Innova 5568 timing light with RPM and advance. I read the instructions and watched some videos on the testing procedure. Also, FYI, I just installed a Facet electtic fuel pump. When observing the timing, whether at idle or at 2000 RPM, and with the timing light set to 4-cycle and 0* advance, the groove on the wheel lined up with the "O --" scribe on the passenger end of that metal tab. When I set the timing light to 8* advance, the groove on the wheel lined up away from the "O --" scribe, at about midpoint on the metal tab.
Here's my question: Assuming I set up and used the test equipment properly, do these observations mean that my IP is about 8-9 degrees off?
