Optikalillushun
No problem, i had to go anyway why not help someone out. This one looks great, ill give it a quick cleaning and make sure the bulbs are ok, get it boxed up n ready to go out.
I'm guessing that that has something to do with the fact that you have a regular-cab truck...IIRC on the regular cabs, the dome light mounts on the back edge and is tilted something like 30 degrees. I haven't had a chance to test-fit mine yet (not going to "really" install it until I have my new cab in place), but my guess is the map lights will be a non-issue on extended-cab and crew-cab trucks where the dome light is mounted level.the only thing is the map lights don't point correctly,but i never use 'em.
something was different with the wiring.it took me a few mins to figure out a fix.can't remember what it took now,but it was different than stock for sure.something about using one of the mounting screws for ground or not.something funky/kinda tricky to make sure all 3 lights worked when they're supposed to.
