fan belt pulley
MidnightBlade
Shiftin' Smooth
Johnstown, PA
is there supposed to be a bolt in the center of this pulley? this is the center pulley on the bottom side of the engine ,the fan belt runs on it. right behind the metal fan on the passenger side.
if possible could you find a part number for the bolt?
is the bolt dia 15/16"? if so, that's the crank bolt. it has nothing to do with the crank pulley. do you need one?
