FACTORY RIMS
treefidy
reno nv
hey guys, will and 05 F350 18 inch rim "8 LUG" fit on a 99 F350 "8 lug" ?
thanks
:confused:
tractorman86
Buckeye, AZ
Yessir all 8 lug 99 and newer are the same bolt pattern(some metric crap!) the only thing you need to look out for is backspacing!!! you dont want a rim with hardly any offset and all backspacing because you WILL need wheel spacers.
jharvey
Shutter Bug
Georgia
Treefidy...what tires are you thinking about putting on those 18's??
My 06 has the 18's and the only tire available in the "stock" size with the "E" load rating is made by continential and they STINK.
John
Towboss
Fomerly Powerboatr
texas, bama and florida
John
john
try my 17s on the dually
BFGs came on it from ford....... BFG website says they no make em,
refer to MIchellin site........ no make, refer to bfg, its sort of a nice circle of things
geuss we go up one size
Muddinkev44
PA
ok.....then will my 96 alum. rims work on my buddys 91...and will the 99 and up rims work on my 96...?
jharvey
Shutter Bug
Georgia
Not sure on the '96 to '91 but the '99 to '96 won't work, the lug spacing is different on the OBS trucks.
sassyrel
iowa
96 to 91--yes--and way back--also ---the van--till 2000???? used the same lug pattern as the older ford 3/4 ton--and 1 ton--
placidoert
