factory ats turbo kit with turbo pump and injectors
greg_a_morton
blossom tx
Guys got this kit off a 93 truck today. Truck had 179000 miles on it. Guys this is a full kit minus 2 nuts, little oil nut on back of block and the tranny dipstick. I am going back to try to get those tomorrow. I am also including the turbo pump and it had a set of BB injectors in it also. I figured this would make a full setup for someone wanting to upgrade. The turbo has no in and out and just enough back and forth to feel it. There was oil residue in the intake like most of these so it could use some seals. $900 shipped to your door in the us. $800 without pump and injectors.
phazertwo
Die Summer DIE!
Crawlorado!
and I need the lower half of the intake box!
When you go back you should look to see if the #7 injector cap, and the return fuel line is routed differently than a NA truck!
PZ
Dieselcrawler
Professional wrench holder
Quakertown Pa
the feed lines are different also. i know i had to bend the first injector line on driverside to clear the airbox. brake line bender did great. but i would get the lines to since obviously they are already off. lol
m2rtin
