fabricating a cold air intake
mech140
mech140
hazard,ky
was needing pics and info on various home made cold air intakes and ram air units going to fab my on and was researching any info will be appreciated.
Bob
dyoung14
Is getting worn out
spencer,tn
Here is what i got and what i think works about the best, on my new truck i may do a hypermax style intake to try it, but here is what i have currently and works on turbo and non turbo trucks;Sweet
mech140
mech140
hazard,ky
Ive seen a few that were fabed to use the cowl below the windsheild. do you have any experience with these?? was wondering would they pull enough air or would it be better to force air with say like a hood scoop plumbed or even a fender mount with a scoop to force air ?????just thinking out loud...
zpd307
Zumbrota, MN
anybody know where to get 4 inch aluminum pipe, somethin with a 45 bend in it. i am also thinking of using pvc sewer pipe....
fcdrifter13
Cross Lanes WV
Air at the cowl is a low pressure zone so it will flow more easily ionto the intake, ramming air into a filter has no effect until high rates of speed. Just look at the Miata guys they done alot of testing on air filer placment mainly because of calss restrictions where ever .5hp helps.
RLDSL
Diesel fuel abuser
Arkansas
Great spot. Gets great flow and lowers EGTs a bunch. I have the Hypermax Cowl induction setup Works GREAT ;Sweet
Optikalillushun
Coal Region, Pa
i thought about putting mine there, but with the slave resivior for the clutch and brake booster there wasnt much room. plus it snows here pretty good in the winter and i dont wanna be suckin in snow haha. i put mine going to the front because it was the easist for me at the time and anything was better than that hookie plastic intake ducting. im gunna put a ***** hose over the end for the winter time, because i like to play in the snow and we all know these engines suck air like crazy.
Dsl_Dog_Treat
Decatur,MI
Got a medium or heavey duty wrecking yard around?
IDIeselman hooked me up with some 4" aluminum tubing off a semi air intake and the rubber boots to go. Worked awesome!
m2rtin
