Sidewinded_idi
anyone ever pull one with their trucks? Should be around 11k lbs 1985 f600 dump truck. Trying to see if I should give it a go. Of course I have plenty of brake just worried about power
did you get your class A lic yet? you have a max weight of 26k/lbs Gross combined on a class "C". With that F600 on your trailer, you're just asking for DOT to have a chat with you.anyone ever pull one with their trucks? Should be around 11k lbs 1985 f600 dump truck. Trying to see if I should give it a go. Of course I have plenty of brake just worried about power
No I haven’t, I normally wouldn’t take this on but it’s only going ten miles that’ll be off highway. But I know I.D like to do it right and get the correct licensing. I’m just trying to get this new venture off the ground and in my area I’ve been swamped with calls.did you get your class A lic yet? you have a max weight of 26k/lbs Gross combined on a class "C". With that F600 on your trailer, you're just asking for DOT to have a chat with you.
if you're out of reach from the DOT you're all goodNo I haven’t, I normally wouldn’t take this on but it’s only going ten miles that’ll be off highway. But I know I.D like to do it right and get the correct licensing. I’m just trying to get this new venture off the ground and in my area I’ve been swamped with calls.
If you’re AG you’re except, just can’t go on highwaysI towed a 40ft equipment trailer with three pulling tractors that weighs 34k with my 92 f350 for many thousands of miles
hmmm.....that tow unit doesn't look like an obs IDI.Welp sad news guys I buckled and used my big truck n trailer 38ft goosneck : ( thing must’ve been heavy because it takes a lot to slow down the stirling but it did, only Slightly.....
You must be registered for see images attachYou must be registered for see images attachYou must be registered for see images attachYou must be registered for see images attach
