So did you check the back pressure or you just went ahead and set the thing to max pressure? I suspect with it being for a bigger engine, the chances of too much back pressure is fairly low. I would guess the hole is sized larger. Does that size work well?
Ours are non-adjustable, butterfly is either open or closed, there are no in-between positions. Well, suppose some can be had by varying the pressure in the air cylinder, but we haven't done that, as there was no need.
But no, never measured the backpressure, actually been meaning to throw a gauge on there for like forever now, but still haven't got around to it... I seem to recall seeing somewhere some listings of the max backpressure allowed before valve float becomes a concern for a variety of engines, and then some fluid dynamics voodoo handled by someone way smarter than I can ever be suggested it should be okay to use the DT 530 brake on the IDI. That said, i don't remember the diameter of the pressure relief orifice in the butterfly, so what you got may or may not be the same as what we got...
But yeah, listen to what Typ4 says - if there is easy access to them, replace the valve springs with better ones, better safe than sorry when you forget to watch your engine speed and hit the brake at 3000+ rpms
