ERROR on speedo cluster
JMD
MI
Helllo , new to the forum.
I recently purchesed a 1995 7.3PSD 2wd auto
I have been searching the net for the last few days but have not found the exact same problrm that I am having.
The speedo reads error and pegs to top speed with little movemnt of the truck.I replaced the axle speed sensor ,not it.
I also went through and tried to recalabrate/rest the speedo.
Here is what happens;
ground the PSOM wire
turn key on with rest pushed
let off restet
displays E 080 ,~I can not find the menaing of this code
press sellect
displays 1000CAL ~and the cal is flashing
and that is were I am at
Is the PSOM seperate from the gage cluster.If so will one work from a F150 gas ?
And the truck seems to run fine But I bought it this way ,so I have nothing to compair to.It shifts through all gears and the Over drive off light does not flash.
Thanks in advance
Jeff
JMD
MI
Replaced the PSOM / instermnet cluster
Fixed the issue
Gdogg
South Lyon Mi.
I think to speedo in the cluster is the same gas or diesel, I have used a F150 gas speedo for a E250 gas
