THECACKLER
I'm building an engine stand to handle the weight of these IDI's and am seeking some "what works" pictures of others setups. I've never seen one up close and personal, only at the fringes of some pictures of the engine themselves. Of particular interest is the geometry of the adapter where the engine attaches to the stand head. I am seeking to go beyond the "Whorber Fright" stand with the 2x4 prop-rod under the front of the engine BS. I would like to have just enough depth between the block and the inside end of the pilot to be able to at least loosely R&R the flywheel on the stand, as an aid to rolling the crank over during bottom end assembly. My plan is to use 7/8" Round bar for the bent arms, six total, coming from the back of the Bell Housing adapter , around the flywheel and down to the 2" SCH160 (2.375 od X 1.9 id ) pipe pilot. This method adds about 5" to the length of the engine & stand head assembly, which increases the tendency for bending at the pilot. I am also assuming that the Cam center line is the best compromise for balancing the engine throughout assembly, but that's just a gut feeling. I am ready to cut steel but would like to see pictures of a "real" DSL engine stand head for a little peace of mind first.
