ghunt
Got a couple questions.
First off- there's been lots of electric fuel pump talk lately, and on that topic I have a question. I got a Carter pump, and everyone said to mount it in front of the selector valve- however, there is not a whole lot of room in which to do that there, and also in front of the selector valve on my truck there is about a foot of what appears to be rubber hose that feels like it is reinforced somehow, then it turns into the metal hardline. So what should I do here?
Also how can I tell which line is the feed line, because they both look very similar and look like they're the same size.
Second- The hardlines running from the selector valve to the rear tank on my truck are EXTREMELY rusty and appear to have a couple pinholes rusted in them (I haven't been using the rear tank, last time I did the truck sucked air and shut off). I'd like to replace these lines but what's the best way to go about it? Should I splice in something like steel brake line with rubber hose? Also what is the factory fuel line size?
