I use two 3.8L Taurus fans. They have 3 wires each, one for ground and one that is low speed and one that is high speed. The way it generally works is like this. If the engine is below temp, once I start driving, even on a hot day, if I'm doing 40 MPH or better, the fan never comes on. Once I stop however, if the low speed fan kicks on, then it's on. It will never go off, until I shut the truck down. But I'm OK with that. It does not draw a ton of current, and after the truck is off, and it sits there cooling my engine compartment for about 5 minutes, it shuts off with no ill effect to my battery. I have had problems with the relays I chose to use originally. What I can tell you is this. You need a relay with a silver contact. Not copper! The copper ones carbon up quickly and then when the fan is required it doesn't come on. This was how I found out my high speed circuit works.
Anyway, when the relays are working, the high speed has never been needed. Over the course of this past summers IDI Weekend, I added two LED's that inform me the status of the fan. What I discovered by adding these, was that the fans spin from road air, even when they are not called upon, and generate enough electricity to light my low speed LED. So this is kind of neat, because I can see the LED start to glow as the fan spins up. It never gets as bright as if the fan was actually commanded to come on, but it does confirm that there is good air moving under the hood. I used to have a lot of cool pictures of how I did this fan setup, and how the project went. But sadly, Webshots killed all our pics and I lost them all. Pretty much wrecked a lot of our tech articles.
http://www.oilburners.net/forums/showthread.php?23946-Electric-Fan-Conversion-for-the-wide-rad
