scarr133
THis normally only happens when its cold out, like now, but it seems to be sticking more now than normal. Any idea on how to fix or adjust this?
Clean the EBP sensor tube, it can get clogged with soot. It is located on the bottom side of the right exh manifold and runs up to the front of the engine near the HPOP.
See if THIS helps.by any chance have a pic of the tube and location????
Youre welcome scarr, glad it worked for you.Did the replacement install for the EBPS and tube and the EBPV hasn't stuck yet. Thanks for the link Stroker!
