E4OD wiring harness?
Rollings
hey guys i need an e4od wiring harness if anyone has one? all i really need is the connector on the passenger side. can anyone help me out, if so how much?
thanks,
jason
NJKen
is a daddy!
Central NJ
FWIW I think ford sells an updated connector kit for the E4OD. Hope that helps some. If not, clipping one from a junyard should be easy enough. Gas and diesel E4OD plugs are the same. Good Luck
Ken
Mr_Roboto
Elyria, near Cleveland Ohio
The passenger side is the solenoid pack connector, to my knowledge it has not changed (like the MLPS connector did in 94).
You can cut the harness from 3/4 ton up pickups or vans (some 1/2 tons used E4OD's also).
If the plastic part is just broken, you can remove the pins and transfer them to a good plastic part. You take out a plastic "wedge" at the bottom of the connector which releases the pins.
Studebaker62
