turbo elk
So after fighting my e4od on and off for a year I finally brought it to a transmission shop that actually had any kind of ideas... the problem was the torque converter would not lockup... I tried to get ideas on forums but nothing positive came of it... so I cleaned all the wiring harness connectors... still no change
I replace the torque converter, with no change ,
then I replaced the solenoid pack, no change...
the valve body and the accumulator, the accumulator had Springs or something rattling around inside of it and I thought this is it... But still no change, except the OD light started blinking...
So after 7 different appointments at three different transmission shops I found one in Vancouver that didn't have blinders on, thay took the transmission out, took it apart and found out that the input shaft seal was the wrong seal ( I had them replace Springs and such too help shift firmness and transmission longevity... and now it's working fine (and it's a good thing because I just bought road flares.)
So if anybody else has any problems like I have had just know it could be internal and external and don't just blindly believe everybody when they tell you it's external.
Thanks to all who helped me.
