About a year ago I completely gone through my transmission and drove it for a good 25K for some of you who know I have been working on replacing my injection pump and injectors .
I had to unplugg the TPS from the side of the OLD pump to get swapped to the new one and am sure I was right on as far as mark or close to it
Drove truck for Good 30 miles with no problem , today was 1st time to use it to tie about 7k weight all went well and after I off loaded the weight w empty trailer the truck started shifting erratically and fast from 1 to 3 the OD is flashing
It Jurk erratically them it smooth out , I checked all the connection to the transmission, also checked connection to Banks trans commander , I even took it off but no difference, I checked the fluid and was right no burn no funnny smell , I checked the connection next to the pump side and it looks secure.
What is the correlation of the connection on the TPS pump side to the tranny ?
When I started the truck that OD does not flash but once I rev it up it comes on
I am going to get an OBD1 to scan the code
Never down time
Never down time
