I have a 1992 f250 that I picked up with a blown transmission. I also picked up a 1989 ambulance. The transmission in the ambulance was supposed to be good. I took the output shaft and extension housing from the blow transmission and the good 2wd ambulance tranny to a tranny shop and had them convert it to 4x4.
I installed the transmission in the f250 and was able to drive it. It didnt drive correct so I pulled codes.
I did put 50-70 miles on it. The symptoms were that when warmed up and having driven a bit, after coming to a stop and begining to accelerate again, it would not engage 1st gear untill the engine was at nearly 1500 rpm. Same with shifting into reverse. When it did get going, it was really winding out 1st gear even when going easy. It would not shift until almost 3000rpm or until I took my foot back off the throttle.
It came back with 29 = insufficient speed sensor input, 49 = 1-2 shift error and 62 = 4/3 or 3/2 pressure switch circuit failed open OR Converter clutch error (E4OD).
I went back and pulled the computer from the ambulance in the hopes that I can swap it in and it will be fine, suspecting that there are some slight differences in the valving that the 1992 computer isnt programmed for.
I did also take it back the to transmission shop and the tech took it for a drive with me. He recommended swapping out the valve body with the one from the blown tranny.
I have started going through the valve body cleaning it out..... used 9 cans of brake cleaner already.
My plan now is to try swapping the computer and rear speed sensor at the diff and perhaps even the MSLP sensor with the other ones before swapping the valve body.
What are your thoughts on this issue and how to best handle it? Thanks alot!
