Hey oil burners,
Having a sudden problem with my transmission. 94 7.3 with E40d, 100kish miles. Truck has been driving fine when suddenly it started slipping into neutral and the od light is flashing. Only way to get it back into gear is to shift lever to neutral and shut truck off and back on. It’ll run normal for a minute and then slip again. I can also shift the lever into 2nd and 1st and have those gears. I have a newer fipl, mlps and vss. I checked the fipl voltage and I’ve got 1.2 at idle and 4.2 at wot, I can’t adjust anymore as the bracket is maxed out. I ohm’d the mlps and vss and they’re within spec. The transmission fluid is full and is pink and not burnt. I pulled all the connectors from those and cleaned them with electronics cleaner and greased them. The trans has 100kish miles on it, unk as I’ve only had the truck a couple years and don’t drive it much. It’s a jasper with tranny cooler installed by the PO. I haven’t had any issues with it up to this point.
I pulled codes at koeo and koer with my code reader and I have no codes. What am I missing? Thanks for any assistance
