I hate the valve stems on my dually. Where can I get a good set that doesn't cost $100. Any favorites out there? I want the extended stems that you can reach with the outter rim.
Kevin
These are the ones that I used on my dually - I liked 'em... They run about 40~50 bucks and are stainless braided.
These are 4 hoses so that both the inner and outar tires are filled via the center of the rim. The brackets rivet into place on the center cap. I liked this way of mounting them better than the spring clip mounting - just thought that it would be a better way never had the spring hold down type just my thought pattern....
Hey Travis,
Did ya hard line them off the rims or did ya just drop em on the stock valve stems?
Goldie would look good with a new pair of shoe laces. :Sly
Beats the heck out of dropping a tire to check/fill the inner tires.
