Mikes91
I'm 3 weeks away from a cross country move, towing a loaded open car trailer and some junq from Monterey, CA to Sumter, SC. Stopping in Lead Hill, AR for some work on the truck.
I'm having the cooling system thoroughly serviced next week because of heating issues over the long grades out of CA and AZ when we moved out here 22 months ago. Hoping that the water pump and fan clutch will pass muster, putting new thermostat in after system flush. Refilling with NAPA coolant and appropriate SCA, plus a little Water Wetter for good measure. Of course, will check hoses.
Does anyone have info on where I can get the upgraded fan clutch for our trucks if mine is bad?
Can anyone suggest proper driving technique for the long hills we'll encounter? With the stock Banks turbo, what are my EGT limits? How can I keep those down, aside from backing off the pedal?
Any remedy for dealing with ******* the water temp gauge? Seems I recall it is best to run high RPMs and back off the throttle to keep EGTs low.
Thank you,
Mike
Thank you,
Mike
