mobilemech
dana 80 out of a dodge has 8x6.5 bolt pattern, up to around 2002 or 03, may work to get you back to the 8x6.5 you need to match.
i don't know the p/n due to the fact I am spoiled by my driveline guy. i get stupid low prices due to the volume of work I bring his way. as a result, I never asked for p/n's but I can post pics between the two. it's significant!Towcat that's the plan. I found a yard with a few of them. The timing is good. The last time it blew I took it to a Driveline shop n had the shaft completely re done. The yoke gets destroyed because the joint explodes. Its a stupid strap type yoke! Towcat what size joint does the dana 80 use? And yes i have the 450 driveline brake and it's operational. If it uses a bigger one then this might be the answer I'm looking for. The next issue would then be the ten lug wheels.
I'd rather have the 10 bolt so i can run a big truck wheel. Just have to figure out if I can use the 450 front hubs on the 350 spindles.
I wonder what shipping would cost. The guy i found has a couple of them and he wants 6-800 each!
or how about a video? *** do you tow? the stock u joints are big enough, if your joints are smaller than that, why not "upgrade" back to stock.Post some pics.
