fiverpuller
Lizard Limo
I know this engine has issues but sheesh! The truck ran till I filled 2 gallons of coolant in the radiator. Within minutes it was hydrolocked. Within hours the oil level was up way high and coolant down. I have been assuming head gasket failures but could it leak that much that fast into the oil? If all goes well the engine will be yanked tonight and I can start disecting soon. But I was just curious if anyone had any gut feelings. It could always be the old "C" on multiple cylinders. There is lots of oil in radiator as well.
I was barring the motor over last night and when I hit a cylinder or two on the drivers bank (suspected head gasket blown) compression stroke I could hear a hissing sound that might be escaping the engine. I figure this to be the air in those cylinders squishing out past the head gasket? Another issue is this thing was leaking a ton of oil. I am just kicking around ideas until I can crack it open and have a look see. Thoughts?
