downpipe w/o turbo outlet
d41
calif. central coast
Good Day All,
Fairly new to deisels and have a question,
How much improvment am I gonna see by just replacing the downpipe and not the turbo outlet ? I have already replaced the exaust to 3" from down pipe back and that helped some I have a banks down pipe I'm gonna install. Is the downpipe and easy install ??? I don't want a hi performance truck just looking to improve a little to pull my little 25' travel trailer. I have already installed gages and bigger trans cooler and this downpipe look like a fairly cheap way to go,
Thanks.
Freight_Train
Traitor to the brotherhood
Gadsden,Al
The banks down pipe will improve things quite a bit.Not as good as a full housing upgrade since you still have that 2 1/2" restriction right at the turbo but the nice smooth ROUND pipe will flow tremendously better than that sorry excuse for a Ford designed down pipe(Why can't Ford put a real exhaust on ANYTHING?) and now that ATS is under new ownership(in a totally different state) they don't make the upgrades anymore.That and the new owner is a shady character from the other thread on this board.
troutwest66
Ricer-Roni The IDI Treat
Post Falls, Idaho
The DP will help on its own. Wait until you see what will come out of our trucks. The factory pipe is squished, literally! I need to do the DP in my truck as well. How much did the Banks pipe cost? When you get the DP done see about opening up the intake. I plan on doing the Tymar style intake on mine and relocate the fuel filter off the alt. bracket most likely.
deanj
You still have a restriction, 2.25 vs 3 inch. changing the down pipe is only half of the battle. You need to improve the intake as well. Diesels :- more air in - more exhaust out. Turning up the pump with a good in take system and good exhaust flow eill "wake up " these engines.
d41
Re:
Got the down pipe for $99, Ordered one day got it the next, great service.
Will the original heat wrap fit or will I need to find somthing elsewhere ? and where ? Also would a guitar pickin, not much of a gear head like myself be able to install this downpipe ?
Thanks for all your help,
Freight_Train
Gadsden,Al
Yea,Pretty easy.Just take a sawsall and cut the pipe under the truck just back from firewall,undo the clamp on the turbo(one nut) and out it comes,slide the new down pipe in,check the fit,beat the lip back on the bottom of the firewall with a BFH and put the down pipe back in and tighten down the clamp.Done.Now drive to a muffler shop and have them weld the pipes back up.
FULL FORCE
Cleveland,Ohio
I had a ton of clearance at the firewall,My banks pipe slid right in,I just got the 3" housing and pipe for a smokin deal,I will be installing that soon,I will have a banks pipe for sale soon!!
I did like the gain I got,I prob would have left it alone if I did n ot get such a deal on the housing upgrade,(150.00) :thumbsup: :thumbsup:
FULL FORCE
Cleveland,Ohio
troutwest66 said:
Where did you find the housing and DP? From ATS I think it's about $550 if I remember someone commenting.
do I have to tell...........
Got someone to end an auction on ebay,lucky deal :thumbsup:
bikepilot
Turbo IDI
NoVA
That was you:doh I was the high bidder till it ended early. The guy wasn't too smart, I would have paid a lot more than $150:)
FULL FORCE
Cleveland,Ohio
I would have paid more too!! I could not pass up the deal,I emailed him and he said 150.00 would take it,I paypaled him right away.
Sorry for screwing you on that deal :sorry: :sorry:
troutwest66
Post Falls, Idaho
I'm sure there's no hard feelings around here. We are just glad someone from the Brotherhood benefits! You're right though. That guy lost out on a gold mine! cookoo
FULL FORCE
Cleveland,Ohio
bikepilot said:
no problem...wanna make a quick $100?:)
Usually I would but I would never find THAT kind of deal EVER again!!
I just got it an hr ago,it was also NEW I thought it was used.
OkieGringo
OkieGringo aka Baja
Claremore, Oklahoma
The seller probalbly works/worked for Banks and stuck it in his backpack on the way out:D . Severance pay:rotflmao . OkieGringo
