In the factory 10.25" LSD there is no S-spring like there is in the 8.8 setups, so you ain't gonna see no springs, ever! Clutches are very well hidden behind the axle gears. The most obvious visual difference between an open carrier and an LSD is the shape of the passenger side of the carrier - this one is cylindrical in shape all the way, while the open carrier has more of a cone shape, as in past the cross shaft and its gears it tapers its diameter down to about the diameter of the bearing at its end. On an open diff there are also two reinforcing ribs around the bolt for the cross shaft, and two more 180* from there - none of this is on this carrier in the pic, this one is cylindrical in shape like that because it has to hold the clutch pack at its end (whereas with the open diff there's no need for this so they tapered them down). So I stand by FACTORY LIMITED-SLIPThere is no clutches or springs just spider gears. I Stand by OPEN DIFF
i dont think its a clear enough pic to say either way. best thing to do is turn it to where you can get a real good shot of the spider gears.
