aiyana7.3
IDI Enthusiast
Hey all I recently installed some overhead switches to control the ignition system in my truck. Essentially, the switches power a system of relays that then connect the yellow power wires to the correlating component wires that are used to power and start the truck. So instead of the black and yellow box under the steering column bridging the power wires to the component wires when the key is turned, the power and component wires are all plugged into relays that the switches activate. The key and the black box the wires used to plug into is no longer being used. only the wires.
The glow plugs are controlled by another switch and is working fine.
So after I wired everything up, the truck starts and runs fine. the only problem is the engine temp and fuel filter lights are on constantly whenever the on button is pressed.
Currently, I have it wired like this:
The on button activate these relays:
R/LG to Y
BK/LG to Y
GY/Y to Y
GY/Y to Y
GY/Y to Y
BK/LB to BK
P/LB to BK
The start button only activates this relay:
R/LB to Y
The glow plug light comes on only when I hold hit the glow plug switch and when cranking but the fuel filter and engine temp light are constantly on. The water in fuel light doesn't come on at all. The truck never had a problem with these lights before I did all this. If it will help to figure the problem out I can upload a pic of the wiring diagram I am using. Does anyone have any idea as to what can be going on? Thank you for taking the time to read this!
R/LG to Y
BK/LG to Y
GY/Y to Y
GY/Y to Y
GY/Y to Y
BK/LB to BK
P/LB to BK
R/LB to Y
