OmniEquipped
Hello. I recently bought a 94.5 PSD with 167k miles and 5-speed. On the way home it lost power and died. Diagnostics indicated the computer failed. I installed a reman computer and fixed it, but it slowly developed an issue where the first 50% or so of the throttle pedal was unresponsive. I took it in and had the computer flashed for OBDII protocol and the latest updates. It ran perfect for weeks after that. Now it has developed an intermittent issue where it cuts out under a light load or while trying to maintain a constant speed. When this happens, the cruise control does not work. Clears up under acceleration. Idles smooth, but the miss will manifest when holding high RPM in neutral. There is no smoke, except a little bit at cold start. There is no CEL and no codes present. Live data is all within normal perimeters. Injectors passed buzz test. High pressure oil is good. Fuel pressure is good. I have replaced ICP, IPR, valve cover gaskets and unhooked the fuel heater.
I'm stumped as to where to go from here. I'm suspect of the computer, but the scanner shows everything is normal. I'm thinking maybe injectors, but it doesn't seem to have normal injector symptoms.
