I've been lurking and reading for abit(very imformative site) and finally got my truck,it's a 86 F250 4WD X-cab 6.9/auto with the older banks turbo.
When I bought it I checked the fluids and they all looked good..trans was over full.I drove it for about 100 miles kept an eye on the fluids,the trans didnt seem to be foaming and I was going to do a full service on everything anyway so I didnt worry about it.
Well the other morning I fired it up and moved it back away from my shop and let it warmup.I jump in and go to hook on my trailer....no drive...no reverse.It goes into park and neutral,but no drive gears.
Got it in the shop last night and dropped the pan.It's clean inside no metal frags.All linkage is working,so I did the filter and fluid and still nothing.I pulled the inspection cover and the T/C is spinning.I then cracked the cooler line and no fluid is pumping.
I've never been inside a C6 is there a bypass of somesort that may be jammed? Like I said the trans looks good inside.I'm thinking the pump took a crap,but hope not.If the trans has to come out I'm goin to do a manual.
TIA for any help,
Stu
TIA for any help,
Stu
