Hey guys I've replaced my whole ac now minus the blower. The resister blew out I just replaced it an ac only workin on low???????? Any helps please I'm headed out in the morning
When the resister blows it usually means the fan motor is pulling too many amps. It will fail to the lowest setting too I think... Its kinda a saftey thing like if the vacuum dies the vents to the defrost of the windshield will blow air only.. The fan is only three tiny bolts and one electrical connection. Most any ford in the wrecking yard will have what you need.e
it can be accessed from the engine bay passenger side very outermost portion with circular flange, easy as heck to change, took me 20 min and i was slackin
Your welcome. This forum halps anyone that asks for help. I very seldom ask and when I do its usually something that takes lots of thought to answer. I have tried to get answers on a Honda Accord forum about the tps on my accord. Its a non replaceble switch and I need to buy the complete throttle body.. Almost $800.00 at Honda but a friend can get it for $250.00. I have read that the two screws can be cut so a flat blade screwdriver will fit. then just by a tps and install it.. Set the volts and your done... Can't seem to get ansers.... Oh well... I'm soiled here I suppose...
Well Gary I would help but that I have no clue on good luck. An yes oil burners is the best friendly forum to be a part of!!!!! Thanks all we have a great cumminty here.
