Dana 44 Questions...
typ4
Newberg,OR
kenneth if you need some regearing that is no prob I can help you with that. I would leave whats in there till you can find a 60.
Dsl_Dog_Treat
Decatur,MI
the solid axle frt dana44hd and the ttb dana44hd are the same strenth, just the ttb bends a little in the middle. i have had a ttb frt ford for ten years and i love the frt end.
Gotta ttb 44 under Mater, my plow truck, and have been beating on it pretty good the past 2 winters with a heavy Western 7'6 plow on it and it usually has 1500 lbs of firewood in the bed and haven't had any problems so far knock on wood.:dunno
I too would like a 60 under the front of it but tis cost prohibitive and I do like the smoother ride of the ttb front end.
david85
Campbell River, B.C.
I don't suppose any of these front end 44s could accept 3.07 gears?
What about the break calipers? Normally these trucks have a nice dual piston front disks, can those be swapped over to the D44, or will that already have good enough brakes on it?
Rot Box
Northern Utah
Lewiston
Yes you can get a 3.08 R&P (or just about any other imaginable ratio) and dual piston calipers for the D44 ;Sweet
david85
I MUST look into this.....I already have a transfer case, all I need is to hang an axle.
I guess a late 70s F250 D44 front is what I would need, but I thought those were the D44HD, and the D44HDs only went down to 3.54? Are the gears between D44 and D44HD interchangable?
FordGuy100
Silverton, OR
Like stated above I am pretty sure you can get 3.08 gears for a Dana 44 front. And as far as the D44 and D44HD I think the gears are the same, just some other things are a little stronger.
k_williams1982
'01 Excursion 4x4
Santa Rosa, CA
I think you're right. I'm gonna just keep looking for a Dana 60 (maybe after I get my taxes back:D). I do think I'm going to stick with the 4.10 gears too. If I find a decent priced set of 3.73 gears I might consider a change, but don't think I'll go any lower than that. Thanks for the offer to help Russ.
Optikalillushun
Coal Region, Pa
if u keep the front open a Dana 44 should live under most circumstances with tires up to 38" if u know when to throttle on and off. but then again i seen dana 44s crunch with stock tires and just stupidity.
FordGuy100
Silverton, OR
newbie question my 89 f250 has a ttb 50
I'm pretty sure it does have a Dana 50TTB. I have always thought ford got rid of the Dana 44HD in their diesel trucks when they came out with the brick nose's, and they switched to Dana 50TTB's in F-250's and Dana60's in F-350's
k_williams1982
'01 Excursion 4x4
Santa Rosa, CA
To my knowledge, ALL 1985 1/2 4x4 F350's got the Dana 60 under the front. Mine is an early '85, so I missed out on the Dana 60...
tke395
