mac
Longish story, bear with me.
On the way to the bar tonight she was stallin out every so often, losing power for a second or two and then coming back. Died completely at a stoplight but fired right back up. Then as we were turning into the parking lot, it died and wouldn't fire up again, so we pushed it into a spot and went and had our fun at the bar. On the way out the girlfriend found a few other redneck guys that new their diesels and got them to give us a hand . They messed around under the hood and tried different combinations of clutch, throttle, and cranking, and got it running in about 10 min. Not 100% sure what they did, but it involved a little ether and removing the air filter (current one is soaked with oil). Took the girl home and the truck ran fine. I headed back to my place a few hours later and it kept stalling out again as I was driving, and I'd press the clutch twice and tap the throttle a couple times (what the guys at the bar told me to do) and it would fire up and I'd keep driving. Well, that worked for about half the way. Stopped at a light and the engine died and wouldn't fire up again. I gave it some ether and tried cranking it, nothing. By the time I remembered they removed the air filter and had gone to do so, the batteries were dead so I don't know if it'll go back to life with a little more air.
So, going off that, is it more likely to be a breathing problem where it could just need a new air filter, or is there something wrong in the fuel delivery system?
