Kagey Robin
The truck is a 1994 crew cab stock turbo, the engine is a 6.9 upgrade getting ready to be installed this weekend (hopefully)
The reason I am posting is yesterday I was researching coolants I read a number of articles and comment on this board and several others and finding a single standard opinion on any coolant (especially brand) was an effort in futility. For every ten posts I read I would get 13 opinions many contrary to each other. Use all green, never green only pink, elcs, never elcs, dca's no sca's, extra sca's NEVER PINK, only Cat red .... ect, ect, ect. By the end I was so confused I could not come to any conclusions. On any other car I would have just asked the parts store guy, and been fine with his recommendation, but on our trucks cavitation is a real and frequently unknown problem, less likely on the 6.9 but still a real issue.
I had heard a few people talk about EVANS coolant, and there were two prevailing opinions 1) it is too expensive, what we have works, why change ...ect 2) People who have used the product and love it, cheap insurance, Last coolant you will ever buy ... ect. As I read, I became convinced that is the coolant for me.
First off is the build. This entire truck was chosen for durability. 6.9 .. 200k easy ... Manual tranny ... 200k easy... Every part I bought was the highest quality I could find, and the longest lasting. The primary goal was durability, and the Evans fills the bill. Money is a concern, but not a primary factor when durability is at stake.
Second ... cavitation is a concern, Evans removes that from the table, it also removes the corrosion element, the lubrication of the water pump, and replacement of my newly purchased Aluminium radiator in 5 years. It not only removes it it takes it off the table for good, if their claims are to be believed. Meaning (barring a catastrophic failure of a hose or radiator) this could be the last time I have to change coolant.
Third ... maintenance, there is minimal ... check the water content of the coolant every 12 mos. inspect components
Fourth .. This can cause you truck to run a little hotter. That is good, Heat in a diesel is not a bad thing, over heating is. The main reason we worry about our engines when they get over 212 degrees is the water will boil out of the block and burn the engine down. This isn't an issue with Evans because it doesn't boil until 375 degrees, it seems like an extra level of protection, and any time I can increase the margin for error that is a good thing. Also the slight increase in temperature is not going to damage the engine, while the oil could break down quicker, I am very religious on changing the oil every 3000 mile which is far below the recommended change.
Fifth .. No pressure in the cooling system. Well no pressure is a bit of a stretch there may be a few pounds caused by expansion, but pressure is completely unnecessary because the boiling point of the fluid is so high. Imagine how long hoses could last if there is only a few pounds of pressure in stead of 10 or more pounds of pressure.
Sixth ... The engine has no fluid in it, and is getting ready to be put in. There is no conversion process, just install and fill with Evans instead of other coolants. Much simpler than to converting later.
I am posting this to hear opinions on my thinking, and to hear from those that have tried this coolant. Am I overly optimistic? unrealistic expectations? faulty logic? uninformed? Ill take all comers, Just for info I am plumbing in a coolant filter with this system, which seems logical if you are planning on running any fluid for an extended period that filtration is a minimal requirement. Have at it!
