Column to gear box shaft
pelky350
Springfield, OR
shaft from column to gear box has extreme play in it, picked up one from salvage yard it came apart and now has play when it was just stuck together and tight 5 minutes ago, I couldn't remover mine either as the slip joint refuses to slip, the new one also refused to move and then it came apart
chillman88
Central NY
Might be because there was a plastic sleeve type thing in mine, I don't see it on yours. Check up inside the other end and see if it slid up inside? On mine it kinda went around that "leaf spring" thing where the shiny is on yours.
pelky350
Springfield, OR
I was readin on it more but haven't been able to retrieve the plastic slide that is likley stuck inside it but sounds down for the day maybe next weekend
Yep. Go fishing for the plastic bushing. It's probably got shoved up in the shaft. It will be real loose without it.
pelky350
Springfield, OR
II'll be attempting again later this week, too many work hours to have the desire to do more work lol
pelky350
Springfield, OR
This one I got was like perfect until I found a way to break it lol I think it was pretty new even the u joint was still tight and not really dirty
pelky350
Springfield, OR
So possibly major problem, went tapping the top half onto the side with the steering wheel he shaft it slides onto moved into the cab towards the steering wheel, what happened and what do I need to do to fix this??
Did the whole thing slide in? maybe you just need to push it back. Then have someone hold it to keep it from doing that again.
pelky350
Springfield, OR
Fixed it sorta I hope, got it out and apart, unknowing to me because I was alone I installed it backwards wheels straight and steering wheel upside down.. used too much force and caused the problem after flipping the steering wheel it went together much nicer. But I am still concerned with the colum shaft movingly in and out like that I'm not sure if I broke something inside it I ran not but truck drives nice and straight now no more steering slop
Wheelsrollin
