Code readers
Ford_Forgotton
OBD-2
www.autoenginuity.com is one of the better scanners out there. It will do all the engine tests that Ford does such as Buzz and Injector Contribution. Works with a laptop or a PDA and has a bluetooth option for wireless use.
Jay even sells these to International themselves as their test equipment, so he got all the powerstroke codes to use :D :D :D
Ford_Forgotton
Your right. I just looked it up. OBD-1 started in 1988. OBD-2 was required to be in place by 1996.
OBD-2 standard was created in 1990, but wasnt required until 96. I just assumed all powerstrokes used obd-2.
Now, technically, the powerstrokes are NOT required to meet OBD-2 standards until 2004. THis is why most generic code readers have problems with vehicles over the 8800 lb limit of OBD2 requirements.
budtoh3zo
Little Smoky, Alberta
So mine is the OBD-1. I just looked were is the hook up to read the computer on it? Its not under the dash were the OBD-2 readers hook up.
Ford_Forgotton
Google says!
7.3L D, 7.3L TD, 7.5L 1988-1995
Left front fender apron in rear of engine compartment.
