TWeatherford
I'm preparing to do the lucky mod on my dual mass, and swap in a kevlar clutch that RLDSL hooked me up with (thanks
). I have never dropped a transmission before, nor changed a clutch, so I'm kind of behind the learning curve. Have a few questions, would love it if you all could give any helpful hints or tips you have.
Here is what I think I need to do:
> disconnect driveshafts on both sides of the transfer case. Anything special on how to take em apart?
> remove transfer case.
> unbolt transmission from crossmember, put jack under it, and remove the crossmember. unbolt it from the motor and pull it all apart. I'll get a transmission jack and have some heavy straps to strap the trans down well.
> I guess I will be able to figure out how the clutch and flywheel come apart?
> I'll have to drain the oil before I remove the flyhweel, right?
> remove the flyhweel and do the lucky mod. should I plan on having it resurfaced and balance checked?
> redo seal on adapter to keep oil, diesel etc, from dripping on my new clutch.
> bolt all the new stuff in. new bolts from Ford for the flywheel, or can I use something else. RLDSL suggested I might need an adjustable clutch rod to compensate for the new stuff. my slave cylinder has been creaking, thinking of replacing it too.
I'm sure its easier said than done. Hopefully it will go well. I have about 3 days to do it in.
