idif250
Aloha,
I was lucky enough to come across your forum and learn from your experiences. I can see there is alot to learn and I can see this forum keeps us from learning the hard way. Unfortunately the many previous owners of my new project (84 f250 idi) didn't read your posts and have had a hard time finding what the original configuration of the factory vehicle was.
I got the truck from a sailor who was shipping out to sea and couldn't get it in gear (for $300) while it was stuck on the side of the road. He said he just wanted to get the money back for the stereo he put in. It was that plastic bushing on the clutch pedal and loose fasteners on the new master cylinder... a 15 minute fix and I drove it home but not over 35 mph(died out at speed). Since then I've dropped 1 fuel tank put in a Racor h20 sep(the original was bypassed), new fuel lines ,filter, Electric pump and she runs strong. That was over the last 5 months. Everytime I look inside there is something wrong or bypassed and I want to thank you all for showing me in the right direction your forum is a Big $ saver.
At this point I've read most posts to the 6.9 idi fuel/glowplug threads and have ordered the tech man from BISHKO.... great stuff lots of pictures
I got the wiring schematics too but they are pretty much what you folks have posted throughout the forum and after reading the post and the struggles with glow plugs and electrical theory I can see many concerns.
1) glow plugs don't work, truck wont start in morning below 70 degrees f.
2) battery drain overnight (below 12.3V and loss cranking amps)
3)glow plug relay unenergized from battery(for a reason)
4)original glow plug relay snapped off in block (later model hose clamped to lifting padeye)
5)5 of 8 glow plugs read around 1.2 ohms the rest below .8( with harness disconnected)
6)several wires melted broken to and from glowplug harness (inside the cab too
All of which I think I can fix but after reading your posts I am hesistant to do anything if I cant get the glowpugs ( which I cannot identify manufacturer other than they are orange) out without pulling the heads.
I backed them out until threads were clear but they wont come out and I'm paranoind about breaking them off.
My plan was to go manual GP with Berus.
Any advice as to how to get them out without breaking would be appreciated.
Thanx for your time.
