argve
Resident Fruitcake
Ok my truck has refused to keep the batteries charged - so I stabbed the batteries while it was running and I get 11.5 volts.
Swapped out the alt to the tune of 130 clams to no gain. Still no charge batteries.
Can change batteries with battery charger and they take the charge and hold it.
Disconnected the grid heaters thinking that maybe they were pulling the system down - nope.
Connections on batteries and alt at pretty good - the connections on the alt I guess could be better but I've seen a ton worse in my life and they were working just fine - these just look normal.
Is there something that tells the alt to start charging.
My check engine light is on and it reports a shorted field in the alt as the code.
I'm getting tired of charging the batteries every night to make sure that I can drive it the next day.
I have never had this type of problem before but will say that I ran into this exact same problem on a neighbors 87 F150 just this week - no output from brand new alts... is there something in the cosmos that is doinking with alts in the Fort Wayne area that I should know about???????
