fields_mj
I'm going to test my glow plugs today and try to change out at least some, and hopefully all of the bad ones. I ordered a set of Motorcraft ZB9 plugs from Rock Auto and they came in this week. I think mine are mostly burned out. Its still dark out right now. I plan to take the air compressor and blow out any junk (dirt/leaves) from around the plugs, then hit them with some KROIL until I run out (I don't have much left) then do the rest with PB. Actually, thinking about it I may do the PB first and save the Kroil for any that give me problems. Then I'm going to go finish putting the motor on my garden tiller, and hopefully get the engine on it started. Then maybe try to get the bad plugs out. If they don't come out very easy, I'll hit them again with the oil, and then go back to my shed/shop and land the wires for my welder onto the new disconnect that I installed for it, and also probably wire up a new disconnect that I mounted this week for my belt grinder, and maybe install a new switch for it too. It's a 2x72 that I built to make knives with, very similar to a KMG. Then go back and start working on getting the plugs out again.
Sound like a decent plan? Any other suggestions that I should follow along the way?
Thanks,
Mark
Thanks,
Mark
