JohnBoyToo
In a not so subtle attempt to get my post count up !!!
How many of you have done the chalk test to get the perfect contact patch for YOUR truck, YOUR tires and YOUR vehicle weight ?
Take a piece of chalk. mark a line across each tire, edge to edge, drive forward about 3 or 4 tire revolutions then stop slowly without turning.
look at the chalk line,
if the center is gone, but you see chalk on the edges of the tire, too much air.
If the center is there but the edge is gone, not enough air.
Keep repeating, add or take out air as needed, until you have even wear, on the chalk across the tread. Works on cars trucks, trailers, lawn tractors, you will be impressed with how much longer tires last, when they have the right wear pattern.
Road Racers will do this to ensure the biggest contact patch to the ground so they can corner best....
so I've heard
so I've heard
