Isn't that coolant hose? Napa lists NBH 602 as EPDM which is not compatible with dyno oil or diesel.
Are you leaving the CDR in its' present location? If not, can't you use the original metal tube to clamp to? If you are leaving it in the present location, can you find a PCV elbow to go into that grommet? That grommet in the above thread fits my 1994 Cherokee 6 cylinder. Unfortunately, the outlet on the elbow is much smaller than the inlet.
