CDD injection line issues
Clb
Another old truck
nannyfornia
I am 100,000 +% sure that they
will " work" on a mock up engine...
But are they going to "fit "an asymbled and running engine?
:sorry:
This chimerica crap kills me.
offroad-anarchy
somewhere in UT, MT, ID or WY
Just a side note to this exact issue. I purchased a set of the china lines off amazon for $38 or so.
They were so badly formed that I couldn't even get them attached to my rebuilt IP out of the truck.
I ended up using paint stripper and polished up my old lines then clear coated them with high temp paint. They look pretty good and went right back in first try.
So, for those wondering about the cheap china ones available out there, I'd take a hard pass.
Here's what a set of originals stripped, polished and clear coated look like. Yeah my two best friends are Moe and Ron. Put those two together and you'll get, kinda, who I be's some times :)
Cheers, Pete
img_1116-jpg.170713
Brian VT
Maine, USA
Am I reading this right? That these lines will throw off the timing because of the lengths being wrong?
ROCK HARVEY
Dayton OH
That’s right, you need them all to be the same length because the high pressure pulse from the injection pump takes time to travel down the line to the injector. Depending on the year and application, some IDIs have the timing adapter on the #1 or #4 line so the line with the adapter will be shorter to compensate. That’s why I measured my new lines in the first place, to find out whether I needed to re-use my adapter or if the new lines were all the same length.
Olds64
Edmond, OK
You can get a temporary injection line that you could keep in your glovebox.
I suppose if you had the crimping tool and access to hose rated for that pressure you could even make an entire set of injection lines for your IDI.
MasterChiefIDI
Mississippi, USA
I would imagine that if all the lines had increased length by the same percentage, timing should be just fine. You just might have to adjust base timing a little but after that, be just fine. But if not all are increased by the same percentage, I could see problems.. Maybe CDD has corrected this issue with their supplier since. Won't know w/o receiver a set and verifying. That said I have enough OE sets to make a good set so I think I will go that route instead of gambling. Thanks for the post.
Curious, I'm probably just measuring with fishing string away from determining this, but does anyone know if I can use a 6.9 passenger bank injection line set with a 7.3 driver's bank injection set? Reason I ask is I wouldn't mine riding myself of the timing adapter if I can and have a good 6.9 pass side set.
Thanks
  • Like
Reactions: Clb
Clb
Another old truck
nannyfornia
Absolutely
Hopefully
Thanks
I've never seen that addressed nor tried it. I don't know if deleting the timing adapter has been addressed yet, but there's mentions of removing it...
Brian VT
Maine, USA
I decided to put new (China) lines on (not fun getting them to fit) when I replaced my pump and injectors. Now I'm thinking about putting the old ones back on. I was never happy with the fit and now I'm wondering if I can get it tuned better with the original lines. I get some smoke at startup and after coasting and then back on the pedal. That may not be due to the lines and tuning but now I'm curious.
Olds64
Edmond, OK
Did you time your IP with a luminosity probe or piezoelectric spark adapter after installing the China injection lines?
MasterBruh
Texas
Yes, from an engineering standpoint lines under pressure will always swell between fluctuating flow. Each time the Injection Pump pushes fuel through every line, they will swell just a little bit. Think of putting your thumb on the end of a garden hose, it will swell up as the water pressure builds up. This happens every single time diesel flows through these steel lines until the injectors pop releasing the pressure, even if the swelling is miniscule, it is enough to mess with timing. That's why everyone here is concerned about the varying lengths.
If the line is shorter than the rest, it will swell less so your timing is essentially "advanced" in that cylinder.
If the line is longer than the rest, it will swell more so your timing is "retarded" for that cylinder.
That's how I understand it. I hope that makes sense :yell:
